Magnepan MMG/Bryston 3B Question for James
0 Members and 1 Guest are viewing this topic. Read 2659 times.
colhogan
« on: 19 Dec 2010, 01:25 pm »
Mr Tanner:
 I was thinking of picking up a pair Magnepan MMG's at a good price,and was wondering if my 20 year-old Bryston 3B will be ok to drive them...
 I ask  because I have heard that ribbon loudspeakers like Maggies can be really tough on the filter caps of an amplifier. :)
 Patrick
  • The Demo is Everything!
    • http://www.bryston.com
Re: Magnepan MMG/Bryston 3B Question for James
« Reply #1 on: 19 Dec 2010, 01:43 pm »
Hi Patrick
Contray to popular belief most Maggies are not true ribbons - they are planar-magnetic. They love high voltage swing and although they have moderately low impedances they are a very Resistive linear load. Long story short the 3B will be just fine on the MMG's
James
« Last Edit: 19 Dec 2010, 02:49 pm by James Tanner »
colhogan
« Reply #2 on: 19 Dec 2010, 02:04 pm »
Great! Thanks for your reply, Mr. Tanner
 Happy Holidays :icon_lol:
 Patrick
joey116
« Reply #3 on: 19 Dec 2010, 02:09 pm »
James, have you done much listening to your 1.7's ? would love your read your thoughts, they seem to be an absolute bargain, unfortunately my closest dealer is about 3 hour away.
« Reply #4 on: 19 Dec 2010, 02:17 pm »
Hi joey
Yes and in two rooms so far they sound different than the 1.6's so I am still adjusting at this point. Will save my comments till I more time with them.
James
MarvinTheMartian
« Reply #5 on: 7 May 2011, 01:14 pm »
James,
Similar situation, but I have a pair of 20 year old ST 3B's.
My question is can i run them in bridged / mono mode into a set of 1.7's?
The manual states 8ohm minimum , but the 1.7's  are such a "nice" 4ohm load.
Will the mono 3B's self destruct or just run a tad hot?
Shawn
« Reply #6 on: 7 May 2011, 01:19 pm »
James,
Shawn
Hi Shawn
Yes they will probably run a bit hot but it should be OK as long as they do not shut down.
James
