0 Members and 1 Guest are viewing this topic. Read 4088 times.
By cheater plug do you mean the little thingie that you plug a three prong plug into so you can plug it into a two prong outlet? Will this be risky in any way to the amp? Actualy, it sounds a little dangerous. The third prong must be there for a reason.
Well, ok. But are you sure I'm not in danger of ruining my equipment (or me) by using that cheater plug? Worth a try. Thank you.
Many components I have only have a 2 wire cord, like my Marantz CD player, Onkyo Tuner, all of my turntables and even my toaster only has only 2 wires.
PS Audio offers a big buck power cord for the 3 prong IEC socket with a removable ground pin, if that would help, assuming the ClassD has an IEC power inlet.
