0 Members and 1 Guest are viewing this topic. Read 1637 times.
However I do not see the two setting options you describe under Advanced ??
Yes it's a FLAC file, I should have thought of that. I am using Ayrewave for play but would like to create playlists in itunes and import to AW. However I do not see the two setting options you describe under Advanced ?? Importing from my HD into AW works fine. I used itunes for several weeks when it was new and it too imported fine from my HD. I believe updates were done about the time the problem started.But going back to my original question, do you know why my music HD cannot distinguish between the two Diana Krall folders, which are different albums, when I try to copy from my stick ?thks for the help.
Did not realize there are two Advanced, the first is checked. What is the Media Folder ? If it's checked what does it do or stop ?
