Poll
How to calculate copper band lenght
copperband length
0 (0%)
copper foil coil diameter
0 (0%)
Total Members Voted: 0
Winding tool for copper band air coils
0 Members and 1 Guest are viewing this topic. Read 1364 times.
Ralle2405
« on: 18 Dec 2010, 12:53 pm »
Hello at all,
the last days ( and nights ) i searched for a tool to calculate copper band air coils. I found a nice online calculator for wire air coils and now I wanna ask You: Do any one knows a same tool like this ( wire coil calculator ): http://www.pronine.ca/multind.htm
Ok, lets explain:
I know the inductance i want to wind ( for example: 0,10mH, 0,12mH, 0,15mH......)
I know the core tube diameter ( example 8mm outside, 6mm inside for the screw hole )
I know the foil width ( example 17mm copper band )
I know the thickness of copperfoil included the isolation foil thickness ( complete thickness is 90µm)
But....I dont know the needed length of copper band included the dielectric foil.
How to calculate this lenghts?
I wanna thanks to all posts.
Ralf
