Help. Computer thinks I am right clicking.
0 Members and 1 Guest are viewing this topic. Read 5743 times.
Randy
« on: 15 Dec 2010, 10:10 pm »
This is driving me crazy. I left click and the response is the right click options. How can I turn it off? I don't care if I never right click.
Pez
Re: Help. Computer thinks I am right clicking.
« Reply #1 on: 15 Dec 2010, 10:15 pm »
One question, what mouse are you using?
One Answer, System Preferences, mouse, uncheck "secondary click"
Congrats your right click is dead unless you hit ctrl-click.  :thumb:
Randy
« Reply #2 on: 15 Dec 2010, 10:37 pm »
I was using the new Mac mouse  without separate clickers, but switched to a Microsoft version. It does it with both mouses. I'll try what you suggest. The problem comes and goes, but has been coming more often and staying longer lately.
Randy
« Reply #3 on: 15 Dec 2010, 10:42 pm »
I think I went to system preferences to do this about a year ago, but it turned itself back on, apparently. The new Mac mouse doesn't seem to have a way to turn off the right click option or at least I didn't find it.  Thanks again.
jparkhur
« Reply #4 on: 15 Dec 2010, 10:45 pm »
Is it upside down.  I know. Dumb. But it has happened to me once
Pez
« Reply #5 on: 15 Dec 2010, 10:48 pm »
It should have the option under mouse in system preferences to disable right click. I have a new magic mouse and the option is there. :scratch: If you have the older Mighty Mouse it may be different, but I seriously doubt it. Do a screen grab for me to see your mouse option menu.
hold command-shift-3 and then upload that to the photo gallery of your choice then post it.
Crimson
« Reply #6 on: 15 Dec 2010, 11:00 pm »
 :thumb:
Randy
« Reply #7 on: 15 Dec 2010, 11:06 pm »
Thanks,Pez. I no longer have the magic mouse. It met with an accident last night when it kept up the right click business.  :oops:   My older wireless microsoft mouse seems to be working fine, now with the right click option turned off.  (I never did think the magic mouse was all that great.)  ( I don't think it was upside down. Both mice were doing it, so I think it must be some glitch in my Mac somewhere.)
Pez
« Reply #8 on: 15 Dec 2010, 11:40 pm »
 :lol: :lol: :lol: :lol: :lol:
Don't you just hate it when your electronics accidentally fall down the stairs? Maybe they wouldn't be so accident prone if they just did what they're supposed to do.  :evil:  :P
Randy
« Reply #9 on: 19 Dec 2010, 03:39 am »
Quite remarkably, with the right click option off in the systems preferences, it was doing the same thing again tonight. Clearly, there's is something weird going on with this Imac, and it is totally annoying.
low.pfile
« Reply #10 on: 19 Dec 2010, 03:59 am »
System Preferences> Mouse
the only think I can think of is that for "secondary click" is switched to Left instead of the default Right.
I am using a Magic Mouse on an i5 iMac on 10.6.5
baumer
« Reply #11 on: 20 Dec 2010, 12:55 pm »
Just a thought, but if I hold my mouse with my thumb and middle finger to move the cursor around and then click using my index finger, (while holding the sides with my other fingers) it always right-clicks on me.
Doug
markie
« Reply #12 on: 20 Dec 2010, 03:42 pm »
The right click is mimicked by holding down the control button and left clicking. So I suspect that one of your two control buttons on your keyboard is periodically sticking.
Randy
« Reply #13 on: 4 Jan 2011, 02:01 am »
This problem continues and seems to be getting worse. I have turned off all right click options.  When it goes bad the left click registers a right click and the scroll wheel magnifies the image. All very annoying. I tried all the suggestions above, to no avail. Any other ideas out there or is my Mac just going bonkers?
markie
« Reply #14 on: 4 Jan 2011, 12:11 pm »
This just might confirm that your Control key is periodically getting stuck.  After all zooming is accomplished by using the scroll wheel with the Control key pressed down.
What you could do is go into System Preferences, under Hardware choose Keyboard and Mouse,  then under the Mouse, uncheck where it says "zoom using scroll ball while Holding (Control)"
Then choose Keyboard and click on the bottom button that says Modifier Keys, and for the Control Key choose "No Action" from the menu.
That should solve the problem, but you won't have use of your usual Control Key functions, if you happen to use them.
Randy
« Reply #15 on: 4 Jan 2011, 03:37 pm »
Thanks, Markie, I'll give it a try.  Although, I have selected "none" for the right click "assignment" it still works normally.  Maybe the mouse is defective, but then the Apple Magic Mouse I had did the same thing.
Crimson
« Reply #16 on: 4 Jan 2011, 03:53 pm »
I think he's referring to a sticky/defective ctrl key on your keyboard, as evidenced by the zoom feature when you scroll.
Randy
« Reply #17 on: 4 Jan 2011, 04:37 pm »
I am pretty sure it's not sticking but there's a chance that I've been leaning on it from time to time and thus creating the problem.  :duh:
But it still begs the question of why if I've turned off the right click functions in the System Preferences, it still works just the same as always.
markie
« Reply #18 on: 4 Jan 2011, 05:40 pm »
Crimson has it. Randy in very short order you can be very sure if the Control Key is sticking/defective if you simply go into System Preferences, Keyboard and Mouse, Keyboard, Modifier, and choose "No Action" for the Control Key.
Then see what happens.  My bet is that the unwanted "right click effect" goes away.  Then of course re-enable the right click on your mouse so you can right click when you want.
