0 Members and 1 Guest are viewing this topic. Read 8427 times.
Finally, maybe the coolest partnership with a 3rd party software is the integration of miniDSP PEQ into REW (Room EQ Wizard). We've told you for a quite a while now how REW is our software of choice when it comes to finding an audio measurement freeware. Well, we're finally delivering in partnership with John, Author of REW, new versions of our plug-ins and REW v5 software allowing: 1) Setup your miniDSP system 2) Measure your setup with REW and let the AutoEQ do its magic 3) Export the AutoEQ settings to the biquad section of miniDSP Advanced. Voila! A simple integration of DSP tuning and measurement with the partnership of 2 dedicated teams! Hope you're liking it, go and download REW if you haven't done so! User manual of miniDSP to be updated shortly. DevTeam
Hi John, Hey where is the best website to learn about these?? Can you post a link to whichever one you think explains this the best? Thanks Ed
Hi Ed, the article I wrote a little while back might be helpful: http://www.hifizine.com/2010/09/subwoofer-equalization-and-integration-with-the-minidsp-2x4/Other than that, it really just depends on what it is that you are interested in doing (?)You can always ask questions somewhere here on AC, on the diyaudio forum for miniDSP, or on miniDSP's own forum: http://www.minidsp.com/support/forumJ
