B100SST Question
0 Members and 1 Guest are viewing this topic. Read 1732 times.
servingko
B100SST Question
« on: 15 Dec 2010, 08:08 pm »
I couldn't find anything on this so thought I would ask here.  Is the amplifier section of the B100 bridgeable?  I know there is no switch but I seem to remember seeing the diagram for bridging two channels of the 9B and thought it might be possible.
  • The Demo is Everything!
    • http://www.bryston.com
Re: B100SST Question
« Reply #1 on: 15 Dec 2010, 11:57 pm »
Hi,
No the B100 amp section is not bridgeable.
james
servingko
« Reply #2 on: 16 Dec 2010, 12:15 am »
audioman999
« Reply #3 on: 8 Feb 2011, 10:15 pm »
Is it possible to use the B100 in a biamped configuration?  If so what other Bryston power amps could be used.  I assume the 2bsst is the natural mate.  what about the 3 or 4bsst?  Also what about the new squared models?
thanks
niels
« Reply #4 on: 8 Feb 2011, 11:31 pm »
As long as the poweramps used have the same gain as the B100 you can use any amp. For instance 28B for the bass and B100 for the mid/treble. Or, you can use vertical biamp (one amp drives only one speaker) with a 2BSST.
« Reply #5 on: 9 Feb 2011, 12:25 am »
thanks
Yes all Bryston amps have the same gain so they can be intermixed without issues.
james
audioman999
« Reply #6 on: 11 Feb 2011, 01:33 am »
thanks for the quick and accurate replies.
