0 Members and 1 Guest are viewing this topic. Read 25614 times.
...do you notice any difference between your line arrays and normal speakers (not counting the sensitivity aspect)?
Vertical arrays can't image vertically (how could they?). Since the main point of having two or more channels is to recreate better imaging, I'm lost as to why arrays show up anywhere (especially in HT).
Vertical arrays can't image vertically (how could they?). Since the main point of having two or more channels is to recreate better imaging, I'm lost as to why arrays show up anywhere (especially in HT). Unless funds are unlimited, best to put the money into a much better single driver or mid/tweet if you're considering extended range drivers (quality over quantity). To be effective the array must have 10 to 20 drivers, so why not spend 10 to 20 times more on a better driver? If you research the cost of drivers in nearly any really high end speakers you'd be shocked.If you're primarily after high sound pressure levels, shop for a speaker that is efficient or can handle lots of power and mate it to a big amp (watts are cheap nowadays).
I'm heavily leaning towards some line arrays for my home theater once it's build due to the high sensitivity. However searching through the web i've seen posts from people complaining about "line array sound". Since this is the only forum I know of where there seem to be quite a few people who have line arrays, i've got to ask; do you notice any difference between your line arrays and normal speakers (not counting the sensitivity aspect)?
Hi,All LA I listen had a huge soundstage and dynamics, I prefer LAs crossoverless, no tweeter, with a good small fullrange driver(4'' to 6'').Unfortunately, the only prob is the price, usually hi. I think LAs best quality are a better soundstage, due the redundancy of drivers.Regards, Gustavo>Never go to a psychiatrist, adopt a cat or dog from the street. On the streets pets live only two years average.
The problem is that with a full-range array design the top octaves really suffer from driver response issues (cone breakup) and dispersion (vertical comb filtering and narrow horizontal coverage). A CBT is best if you want to go with single drivers; however the cone diameter is still limited to around 2" for best performance.
We've got sb / fountek
Yes, but the narrow sweet spot and high distortion aren't for everyone.
