Leave Half Wall Open?
0 Members and 1 Guest are viewing this topic. Read 2652 times.
vintagebob
« on: 14 Dec 2010, 07:13 pm »
I have a half wall on the left side of my system.  Would it make sense to put some diffusion or absorption panels in that space instead of leaving it open? (The computer stuff is not normally there)
bpape
    • Sensible Sound Solutions
Re: Leave Half Wall Open?
« Reply #1 on: 14 Dec 2010, 07:16 pm »
I'd want to see what's through the opening.  In general, you'll want to make that side as similar to the other side as possible.
Bryan
vintagebob
« Reply #2 on: 14 Dec 2010, 08:26 pm »
OK.  The other opening is covered with heavy curtains.
« Last Edit: 18 Dec 2010, 09:21 pm by vintagebob »
« Reply #3 on: 14 Dec 2010, 10:44 pm »
Hey, how did you change speakers so fast  :wink:
Will probably need a pic of the right wall too.  Ultimately, close the hole but in reality get diffusion or absorption symmetry on the left and right first reflection points .
vintagebob
« Reply #4 on: 18 Dec 2010, 04:46 pm »
OK.  Right side and center shots.
bpape
« Reply #5 on: 18 Dec 2010, 06:31 pm »
Since you really can't do a lot with the left wall past the opening, closing it up would be a good thing IMO if that's an option.
Bryan
