0 Members and 1 Guest are viewing this topic. Read 7707 times.
Quote from: coke on 14 Dec 2010, 04:29 pmCongrats!Setup suggestion - Little or no toe-in
Maybe this will get you started ? http://www.audiocircle.com/index.php?topic=78833.0
I'm a bit puzzled by the sarcastic rolling eyes, though.
That's great. That is what my brother has, very nice clean look. And that RAAL tweeter is really specialYou'll have plenty of time to experiment. In another thread you were asking about depth, front to back. A little more toe-in will increase the depth, less will widen the soundstage. I have the HT3's and am surprised how much toe-in I ended up with. For 30+ years I have usually had little or no toe-in and that is how I started with the 3's, but it has changed. My brother too with his 2's. Ours would be a triangle with the axis meeting a few feet behind us. In 45 days you be experimenting yourself.
Saturn, I guess that means how dare you even think about asking a setup question (you haven't actually asked any setup questions yet) without first searching for an existing thread on the subject! Steve
As a group I don't think we have that much experience with the effects of toe in on the RAAL version of the HT2-TL.
Gee, thanks guys. I've never trashed anyone for asking a question. The rolly eyes meant that the referenced thread may not be all that much help.As a group I don't think we have that much experience with the effects of toe in on the RAAL version of the HT2-TL.
When you get your speakers, just take some time to play with positioning. You might be quite amazed at what only an inch will do.
One might be surprised what 1/8" will do.
In my gallery there are a few pics of my HT2-TLs in cherry, mine are the 3/4 inch. I have heard both and they sound the same to me and those two inches mean a lot in my small room. Yes, 45 days is a long time but well worth it!
One might be surprised what 1/8" will do. In the Master Set placement procedure you move it that much between tests! Bob
