0 Members and 1 Guest are viewing this topic. Read 4238 times.
We understand that we've made quite the investment in your rehabilitation, what with the new front surface mirror, new ground glass, shutter clean and lube and so forth. Those things don't change the fact that you're looking tired and even acting a little slow at 1 and 1/2 second speeds.......the doctors tell us you're clean, just an elderly slow speed escapement. It's very consistent, and we could make an adjustment, but that's not really the issue. We're trying to present a youthful image here, and frankly, your old paint just doesn't do that for our company. Your uncoated Tessar 75/3.8 is still plenty sharp, but your results are just different from your modern coated fellow employees. The lab even reports they need to vary the print contrast of your negs....that will never do! Once they lock on to a combination for others, your results should be the same. All of your original equipment accessories will be permitted to leave with you...your intact leather ever-ready case, lens cap, Y2 filter& case, and hood with case....that's all fine. Your ground glass back and four film holders can go, too. We find your ability to use sheet film quaint, but not in line with company policy: 120 rollfilm ONLY! We've added three of your B&W shots to the above files. The company has agreed to pay your relocation to anywhere in the U.S. at no cost, should someone decide to give you a job with them. Overseas employers should contact us BEFORE hitting the "Hire me Now " button! A uniformed employee will escort you from the premises the next business day to see you to your new location. Good luck, Mr. Model 621. We enjoyed your term here with us, but are moving in a different direction."...Thanks, Jo
A few pages I skimmed said it is real lizard skin. This specific ad doesn't say. Here's the link:http://cgi.ebay.com/New-Rolleiflex-2-8F-AURUM-Gold-w-Xenotar-80mm-f2-8-/310215533545?pt=Film_Cameras&hash=item483a4963e9I found it as I was poking around looking for my own fantasy, probably-don't-need-it-but-it-sure-would-be-cool item, a large format Xenotar lens with an ƒ2.8 aperture.
A bit unwieldy - kinda if you are going to do that why not just use LF.
