FS: Xlo Reference 2 10a IEC ac power cable 6 ft excellent cond.
0 Members and 1 Guest are viewing this topic. Read 5299 times.
ua100k
    • Merrill Audio
$100 plus Shipping.
Looks new, Mint condition. This cord is far better than its retail price suggests.
Until the new signature 2 Type 10.2 and the UnLimited Edition power cord ,this was XLO's very best. It's UL listed,patented,and in the world of High End accessory power cords,it's A MAJOR BARGAIN! Type 10A is a sonic "stunner " that easily outperforms cables more than four times its price. Cleaner background and very significantly improved bass definition,soundstaging,image,focus,detail resolution and "air".Special materials and construction are featured,and construction is 12 AWG,shielded and double grounded.
IEC15 Amp U.S. style. Hubbell and wattgate 320 connector.
Award winning patented 12 Gauge design Proprietary Field-Balanced geometry Shielded and double-grounded 6N(99.99997% pure) Laboratory Grade copper construction
Length: 6 ft approx Weight: 1 kg
Diameter: Approximate 14mm
Conductor: 12 AWG 4N (99.994% pure) OFHC copper conductors
Patent: Advanced Technology protected by U.S. Patent Number 5,110,999
Geometry: Field-BalancedTM winding geometry Connector: Standard US Power Plug 6 ft XLO REFERENCE 2 10AC US Power Cable
Please send me an email with your offer.
Thank you for looking.
Wattgate 320 Description.
he new improved construction of the 320i features an elegant polycarbonate rear housing in theater black with a durable hi-temperature rated front housing. Improvments were made to the Perma-Lock terminations. The faceplate set screws are now of stainless steel. Additionally, there is a dust seal to protect the wiring chamber.
The 320i has been designed to be adaptable to a wide range of power cables. It has a powerful mechanical cord clamp with a removable insert to accommodate cable diameters from 0.300" (7.62mm) to 0.655" (16.63mm).
Installation has been further simplified due to clearly marked, tightly-spaced, funnel shaped holes to guide the conductors into the unique Perma-Lock terminals. The Perma-Lock terminals work in the following way: As the terminal screw tightens down on the contact tang, it compresses the wire underneath the tang, causing the screw to exert an upwards lift of the collar overleaf. This lifting action "locks up" the threads on the screw.
Stress-relieving of the terminals is virtually eliminated. Heat cycling and vibration cannot loosen the screw. The real departure the 320i takes from the traditional IEC lies with the contact elements themselves. Our contacts are large and designed to possess a high spring rate to securely grip the connector on the component.
Theater Black 15a at 125VAC
Hubble HBL 8215c
RoHS Compliance : Yes
Description
CONN, HOSPITAL GRADE PWR ENTRY, PLUG 15A
Connector Type:Hospital Grade Power Entry
Current Rating:15A
Body Material:Hospital Grade
Connector Mounting:Cable
Connector Type:Power Entry
Contact Material:Brass
RoHS Compliant: Yes
