new design suggestion
0 Members and 1 Guest are viewing this topic. Read 3413 times.
bizyz
« on: 6 Dec 2010, 04:10 am »
here is my suggestion for a new design in an omega speaker:
i would like to see a book shelf speaker similar in size to my beloved ruarks made in england.they are about 11 inches in height and 6 inches wide and are in a walnut finish.they are bi wireable as well as bi ampable as well.
have you considered producing a mini monitor speaker?
ZLS
Re: new design suggestion
« Reply #1 on: 6 Dec 2010, 12:16 pm »
    At this point it might be helpful to remember that Omega-Hoyt Bedford Loudspeakers are single driver speakers.
    It certainly is possible to bi-wire single driver speakers; the more applicable question would be why anyone would want to.
bizyz
« Reply #2 on: 6 Dec 2010, 09:55 pm »
ah,i understand what you are saying but what about the possibility of bi amping for more power,better bass grip,more detail,etc?
JohnR
« Reply #3 on: 7 Dec 2010, 12:00 am »
If you were to do what I think you're suggesting, you would have two amplifiers being shorted together at the loudspeaker...
opnly bafld
« Reply #4 on: 7 Dec 2010, 12:01 am »
Biamp a single (1) driver speaker, with a single (1) voice coil?
Here is a picture, maybe that will help.
Louis O
« Reply #5 on: 7 Dec 2010, 12:59 am »
Hi bizyz,
ZLS, JohnR and opnly bafld are right. Can't be done.
1 Driver and 1 amp. Beauty of simplicity.
Louis
bizyz
« Reply #6 on: 7 Dec 2010, 02:27 am »
eureka!the super 5 bipole with a super hemp sub woofer!
DonB
« Reply #7 on: 7 Dec 2010, 04:55 am »
You could always to the mono-block route  :roll:
« Reply #8 on: 8 Dec 2010, 05:38 pm »
Yes! I've done that, with no stinking whizzer cones, no binding posts, and reach below 30 Hz without a sub.
rollo
  • Rollo Audio Consulting -
« Reply #9 on: 9 Dec 2010, 05:33 pm »
 A two way design with no crossover.  :o
charles
Louis O
« Reply #10 on: 28 Dec 2010, 11:46 pm »
Hi bizyz,
Technically your right. This can be done with the bipoles.
Louis
