YS Audio A2-SE fully balanced tube preamp (remote, box, tubes)
0 Members and 1 Guest are viewing this topic. Read 2448 times.
doctorcilantro
PRICED TO SELL. Bought the silver version in Summer but recent economic turns have led me to return to just using a DAC to my amp. This is an well-executed preamp. I will provide upgraded tubes if you inquire for a reasonable cost. Comes with original box, remote, stock tubes, and manual.
$1190
There is a positive review on enjoythemusic.
Checks fine or Paypal Gift (please cover 3% for Paypal Goods payment).
Fully Balanced Design
One High grade 5687WB tube and Two 12AT7 tubes for each channel. Remote Control with input select , volume control , mute All input and output both with XLR and RCA(4) stanard inputs , (2) sets of main outputs and (1) Record out.(1) Processor input with Home Theater Bypass loop (HT/BP)Controls : L Gain , R Gain , Main Volume , Input Selector , Power On/OfRemote Control : input select , volume control , mute Output :  Two Main with XLR / RCA , One Record with XLR / RCA ,Input : L1 , L2 , L3 , L4 with XLR / RCA , Processor with XLR / RCA ( HT/BP )Output Impedance :  500 ohms Balanced , 250 ohm SE Main.Recommended load:  10K ohm or greater ( Balanced ) , 5K ohm or greater ( SE ). Frequency Response:  8Hz ~ 250KHz(-0.5dB)T.H.D : 109dBChannel Balance: 95dB(2Hz ~ 20KHz)Phase Mode : NormalMax Output : 46VLine-Stage Tubes : 4pcs 12AT7 , 2pcs 5687WBDimension: 455mm x 350mm x 120mm (W x D x H)Weight: 7kgPower Source: 110-127/220-240V,50/60Hz
Phil A
Just curious as to where it is located in case someone is local and wants to hear it?
doctorcilantro
Tampa Florida.
j
doctorcilantro
bump
doctorcilantro
sold
