For Sale: Accessories
MIDAS TOUCH PHONO CART. ISOLATOR
0 Members and 1 Guest are viewing this topic. Read 1781 times.
doctorcilantro
5 Dec 2010, 05:35 pm »
The isolator (MIDAS TOUCH) has 3 spikes facing up and 3 spikes facing down, all adjustable and can be located to suite arm and cart. True isolation of the cartridge from the arm. You will hear better focus, better extensions and more solid sound. It is the same as having cones / spikes under the turntable and also speakers as well as equipment. The cartridge vibrates all the time while it is tracking. Should be used with VTA adjustable tonearm. $80 shipped
there are some pics
here
Last Edit: 27 Dec 2010, 04:00 pm by doctorcilantro
doctorcilantro
Re: MIDAS TOUCH PHONO CART. ISOLATOR
16 Dec 2010, 03:40 am »
bump
doctorcilantro
Reply #2 on:
27 Dec 2010, 03:42 pm »
bump
orthobiz
RIP John TheChairGuy 2013
Reply #3 on:
28 Dec 2010, 03:01 pm »
Does this somehow facilitate azimuth adjustment in otherwise "unadjustable" tonearms?
And "thanks for nothing," doc. Now I have to check stereolist everyday!
Paul
doctorcilantro
Reply #4 on:
28 Dec 2010, 03:07 pm »
I believe you could make fine adjustments to azimuth. Let me get you a picture from the top.
doctorcilantro
Reply #5 on:
28 Dec 2010, 04:41 pm »
there are screws for the empty holes (this is a stock photo)
