bryston 12b preamp
0 Members and 1 Guest are viewing this topic. Read 7135 times.
ancient hippy
bryston 12b preamp
« on: 4 Dec 2010, 05:31 pm »
would appreciate any info on this preamp as i have an opportunity to purchase. how would it compare with the .5 and 1b
colhogan
Re: bryston 12b preamp
« Reply #1 on: 4 Dec 2010, 06:29 pm »
The 12B was the flagship Bryston Preamp in the late'80's & early '90's before the Bryston BP-20 came on the scene.
I seem to recall it having a great MC Phono stage,as well as having a seperate Record/Listening feature,& having 2 AC outlets on the back pannel.
The build-quality was typical Bryston,which is to say it was excellent! The sound is more forward-sounding than the later Bryston Preamplifiers,(Like the BP-20),but still very enjoyable.
 The price of the unit was around $1200.00 USD,so if you can score it at a great price,go for it!
rob80b
« Reply #2 on: 4 Dec 2010, 07:53 pm »
The sound of the 12b is identical in sound to the .5, clean sounding but a bit livelier than the current lineup or as Colhogan mentioned more forward. So if you've used the .5 before, same sound just more options.
The 1b should be similar.
The thing to keep in mind is that Bryston does not radically change their basic circuitry but work on improving it by trying different layouts to reduce noise levels and implementing better components when they become available.
Robert
vegasdave
« Reply #3 on: 4 Dec 2010, 09:54 pm »
Yeah, if you can get a good deal on it, grab it! You also might wanna send it into Bryston to get it checked out.
ancient hippy
« Reply #4 on: 6 Dec 2010, 04:21 pm »
thank you all. your input is appreciated. actually sold a .5b not long ago so im familiar with its performance
