Awesome Arte Forma I-150 Intergrated Amp FS
0 Members and 1 Guest are viewing this topic. Read 1693 times.
Rocket_Ronny
    • ScriptureSongs.com
« on: 2 Dec 2010, 09:24 pm »
Price Drop to $850.00  :duh: This is a Killer Deal folks.
Read the professional review on the amp at:
http://positive-feedback.com/Issue53/arte_forma.htm
Here is an really great deal on an outstanding 150 watt integrated amp that easily plays with the big boys.
I am going to upgrade in the Arte Forma line, so reason for the sale. It's not that I am not happy with it, quite the opposite. I love it, so let's go for some more.
Retail pricing is $1400.00 and this amp is $995.00  It is basically new and just broken in. I am going to upgrade to another Arte Forma amp.
Don't let the low price fool you. This has really top shelf sound. I absolutely love this amp so I am going for more of a great thing. It has stunning 3D imaging and localization. Amazing detail and timbre. I never thought a grand could buy such a top shelf amp, but it does. It is shockingly good.
See my review at  http://www.audiocircle.com/index.php?topic=87635.0
Specifications:
Output Power, Continuous RMS watts:  150 watts @ 8 ohms, 250 watts @ 4 ohms
Peak Output Current:   10 amps
Frequency Response:    10 Hz – 35 kHz, -3 dB @ 8 ohms
Dynamic Range:   120 dB - a
THD + N:   < 0.03%, Typically .01% @ 1 kHz
Common Mode Rejection Ratio:   > 90 dB, 20 Hz – 20 kHz
Inputs:   4 pair Unbalanced (RCA)
Outputs:   1 pair Parallel Binding Posts per channel
Power Consumption:   Idle – 35 watts, Maximum – 800 watts
Weight & Dimensions:   45 lbs / 20 kg ,  (H) x (W) x (D) 120mm x 430mm x
380mm
Rocket_letting you know about a great deal_Ronny
« Last Edit: 4 Jan 2011, 04:31 am by Rocket_Ronny »
Rocket_Ronny
Re: Awesome Arte Forma I-150 Intergrated Amp FS
« Reply #1 on: 4 Jan 2011, 04:33 am »
This deal is getting very tasty. Price drop to $850.00.
Rocket_Ronny
« Reply #2 on: 9 Jan 2011, 01:10 pm »
Check your PM
