Tang Band W6-1139SI Subwoofer
0 Members and 1 Guest are viewing this topic. Read 2047 times.
sts9fan
« on: 1 Dec 2010, 05:56 pm »
Anyone ever build a sub with these drivers?  I have seen the tapped horn plans which look badass.  Anyone build a more conventional box?  I am thinking of building three for a multi sub array.
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=264-832&ctab=2#Tabs
Kris
JoshK
Re: Tang Band W6-1139SI Subwoofer
« Reply #1 on: 1 Dec 2010, 06:03 pm »
I am planning to build some tapped horns with them for distributed array of THs.  They are small enough to pull that off.
sts9fan
« Reply #2 on: 1 Dec 2010, 06:40 pm »
That is possible.  I may make two of the 38hz ones and then use my current sub below that.
