0 Members and 1 Guest are viewing this topic. Read 8994 times.
It seems I remember reading (though never saw or heard) that back in the day, people used to stack two Advent Largers together for each channel. I think I've even heard of it done w/ Quad electrostats.So could the same thing work w/ Maggie panels? A member has offered to sell me just the panels (drivers) from MMG's. I might still try to find a compete pair too in order to compare my modifications to stock (and have a pair to listen to in the interem) and that got me to thinking about a stack. Now I'm sure you can't just wire them in parallel, if both crossovers were in place, as the impedence would drop too low, but could one crossover handle both, or would it need to be completely redisigned by a knowledgable crossover artist?Or is my lack of sleep from working 3rd shift just melting what remains of my brain?cheers
This is my first time through the Planer circle, and I came across this thread. I don't own Planer speakers, but just had the opportunity to audition some equipment at a new acquaintance's home and he had 2 pairs of 3.6Rs in a "T" configuration, wired in series. By "T" I mean each channel was 2 speakers in a "T" shape. One panel facing the listener, and one panel at a right angle to the first. I'm not sold on Planers by any means, but the soundstage in his room was like nothing I had heard before. Amazing placement of the musicians, and the "Sweet Spot" was about 10 feet wide. I'll see if I can get a picture of his room. Others using this technique?
RustyI wouldn't call this a technique - it doesn't make sense. It must mess with the dispersion characteristics and cause lots of cancellation of frequencies. Planars already suffer from lots of comb filtering; this would exacerbate the issue.
I use Martin Logan Summits (woofers disconnected) along side of Magneplanar Tympani IV basspanels (modified). Combining the best properties of each speaker (electrostatic midrange and highs (no xover) and the Tympani IV bass. The result of this combo is fantastic imaging, low leveldetail and great depth and a huge sound-stage. The Magneplanar Tympani bass panels are bolted together and to the floor for bass that is very powerful, well controlled and has great transient response.
You say those are wired in series vice parallel. I assume this is only because of lack of power amp capability to drive 2 ohm loads?I can't tell by looking at the photo's but I'd be interested to know the polarity configuration.Dave.
If the main speaker woofers are moving toward the listener are the secondary woofers moving inward or outward?It seems to me that with this configuration you'd want to "offset" the "T" so the main speakers intersected the secondary speakers at a point between their tweeter and mid/woofer. I can't tell from the photo's if it's currently that way or if the "T" is symmetrical.I have a second pair of MMG's and I will probably try this......although the concept seems silly because it ruins/aborts the nicely engineered dipole radiation Magnepan's exhibit. This seems pretty "gimmicky" to me. Cheers,Dave.
