FS: Samsung TX-S2782H Slimfit CRT HDTV
0 Members and 1 Guest are viewing this topic. Read 1311 times.
woofersus
  • Authorized Dealer: Melody & Angel City Audio
    • East Street Audio
« on: 1 Dec 2010, 01:40 am »
I have a Samsung TX-S2782H up for sale.  It's from the Samsung "Slimfit" series of CRT's and while no match for an LCD in the space efficiency department, it's quite a bit less bulky than most other 27" CRT's. (16.5" deep)  Mine is 4 years old and has none of the geometry issues that some complained about with this series of tv.  There was in the past a tiny bit of discoloration in the lower right hand corner of the screen but after a careful adjusting of my speakers it seems to have gone away, so it isn't permanent.
This TV has great picture quality and supports HDMI so you can connect it to all modern devices easily.  It makes a particularly good display for gaming since it has no ghosting issues and input lag is virtually nonexistent.
This is for pickup only as I no longer have the box and don't care to package up a 90lb. tv for shipping.  It includes the remote and owner's manual.  Asking $100
Samsung TX-S2782H specifications
General
 * Product type CRT TV
 * Diagonal size 27.0 in
Video
 * Technology CRT
 * Display format 1080i
 * Image aspect ratio 4:3
 * Progressive Scan Progressive scanning (line doubling)
 * Comb filter 3D-Y/C digital
 * Color temperature control Yes
 * Supported DTV resolutions 480i , 1080i , 480p , 720p
 * TV Tuner
 * TV tuner presence Yes
 * HDTV Tuner Yes
 * Digital TV tuner ATSC
 * Analog TV tuner NTSC
 * Secondary audio program (SAP) Yes
Audio
 * Sound output mode Stereo
 * Surround mode Yes
 * Sound effects SRS TruSurround XT
 * Total output power 20.0 Watt
 * Speakers included 2 speakers
 * Speaker system speaker type Right/left channel speaker
 * Additional features Auto volume adjustment
 * Speaker form factor Built-in
 * RMS output power 10.0 Watt
 * Speaker system speaker qty 2.0
 * Audio controls Balance , Equalizer , Sound mode
Convenience Features
 * Closed captioning Yes
 * Parental channel lock Yes
 * V-chip control Yes
Connectivity
 * Video interface Composite , S-Video , Component , HDMI
 * HDMI ports qty 2.0
Remote Control
 * Type Universal remote control - Infrared
Power
 * Power device Power supply - Internal
 * Power device nominal voltage AC 120 V
 * Power consumption operational 180.0 Watt
 * Power consumption stand by / sleep 2.0 Watt
Dimensions & Weight
 * Dimensions (WxDxH) 30.4 in x 16.5 in x 23.3 in
 * Weight 90.4 lbs
tjohnusa
Re: FS: Samsung TX-S2782H Slimfit CRT HDTV
« Reply #1 on: 11 Dec 2010, 02:32 am »
Where are you located?
woofersus
    • East Street Audio
« Reply #2 on: 11 Dec 2010, 03:01 am »
Mount Vernon, Ohio
Sorry, I forgot it's not shown right by my username on this forum...
