Rotel RSP-1066 or Outlaw Audio 950 Pre/Pro
0 Members and 1 Guest are viewing this topic. Read 2092 times.
earlmarc
« on: 11 Mar 2004, 12:49 am »
Which processor would you recommend between these two? Has anyone compared them?
byteme
« Reply #1 on: 11 Mar 2004, 12:45 pm »
if I remember correctly there was a TON of people posting about these over at http://www.hometheaterforum.com do a search in there and I think you'll be pleasantly surprised at how much info comes up.
John Casler
Re: Rotel RSP-1066 or Outlaw Audio 950 Pre/Pro
« Reply #2 on: 12 Mar 2004, 02:28 am »
Quote from: earlmarc
I would suggest that for Value/Performance it is hard to beat the Outlaw, but I think the Rotel is better in most areas.
Also in the Rotel's price range is the new, P-965 from Sherwood NewCastle.  I just picked one up and so far is is a very good unit, and it has all the trimmings.
Marbles
« Reply #3 on: 12 Mar 2004, 02:42 am »
The B&K REF 50 was reduced to $2000 MSRP (from $3000) which means a street of around $1500 if you shop carefully.
I would recommend this over the other two,
