0 Members and 1 Guest are viewing this topic. Read 14715 times.
I own a pair of 845 based SET monoblocks on Zu Definitions(101db, 6ohm) and it is a spot on match for the speaker. That being said, I have noticed that the Zu's really come alive with high watt amps despite the need for only a few watts to drive them to satisfying levels. I was considering having a kt88 push pull amp made and it was suggested to me by a great amp designer that a hybrid amp (not a hybrid integrated) using 5687 tube input and mosfet output would be a great alternative to a pure tube amp and he believes his hybrid amp "smoked" a no holds barred amp he created. I am very reluctant to bite on this idea given my track record of never enjoying a single solid state amp enough to keep. I'm wondering if any tube lovers have had success with hybrid amps that make them not miss their tube amp?
If you were to go hybrid, go with a system that has a tube output stage (AKA: KT88 or 6550) and a solid-state driver stage. It has to be a design which is uncluttered or else it's all for naught. The added power brings with it better, cleaner dynamic range. Nothing wrong with a high wattage ceiling!
Previous designs generally employed vacuum tubes in impedance-isolated preamp or pre-driver stages. BK Butler's Tube Driver BLUE technology places the triodes exactly where they should be: DC coupled through the output power devices to the speakers. Therefore, the tubes are positioned to naturally and actively respond to the dynamic speaker load. This also completely eliminates one of the most inefficient and non-musical components in a typical tube power amplifier: the Output Transformer. Without the phase shift and induction generation caused by hundreds of turns of wire and massive core iron to overcome, BK Butler's newly patented current multiplying DC coupled circuitry allows the 6SL7GT output driver tubes to directly operate into the constant ratio-reduced speaker load. This novel design allows the tubes to safely produce authentic power vacuum tube dynamic characteristics hundreds of times greater than their original design capabilities.
As you can see, I have had amps of all flavors and sizes. The one thing I can say is tubes are NOT inherently better than SS/hybrid amps. It all depends on your room and speakers.
Having owned a Butler TDB2250, I can enthusiastically recommend it. No, it doesn't sound like an SET. It does have the midrange "magic" of an SET but with DRIVE! This is especially noticable on dynamic, full range orchestral music. Where I think it gets most everything "right" is in its lack of feedback. I find this makes more of a difference than output circuit topology. It was one of the best amps I have used in my 40 years of audiophile insanity. By way of comparison, this is a partial list in no particular order (I can't remember them all) of the amps that I have had over the years:SAE MK IIAudio Research D76ASAE MK XXIIIVAC 100/100Sonic Frontiers Power IIInnersound ESL ampGenesis StealthNew Audio Frontiers 845SE Special EditionAs you can see, I have had amps of all flavors and sizes. The one thing I can say is tubes are NOT inherently better than SS/hybrid amps. It all depends on your room and speakers.
