0 Members and 1 Guest are viewing this topic. Read 11188 times.
Hey John, take a look at Shirt-pocket's "SuperDuper!". It is great software for disaster recovery.
OK, but I have the desktop using Time Machine to a firewire drive, and the Air using Time Machine to the desktop. And occasionally, I remember to run my rsync script to back up my home directory on the desktop to a network drive.What I would really like is a way to automatically keep my my Documents directory in sync on the Air and the desktop. And provide a way to recover files in case something goes wrong.
MobileMe - My original plan expired 6 weeks ago, bought the one year renewal keys on eBay for $39.99. I received them electronically in 24 hours. I use the backup utility in Snow Leopard, you can specify the source folders/files and the destination. In my case iDisk is the destination and I've programmed daily backups for critical folders, works a treat Still haven't figured out the benefits of using SuperDuper, doesn't Time Machine/Time Capsule take care of all this?
SuperDuper creates a clone of the HDD and makes it bootable. Time Machine is a built-in backup software that creates backup of your data. That's it.
It's just not bootable, but to make the SuperDuper bootable with the "convenience" sales pitch, you need to use the right form-factor drive and the skills to swap it out. Otherwise you still have to boot SuperDuper as a USB/FW drive and then copy the contents over to the main HDD, which is no gain.
With the MAC OSX install disk you can restore your Time Machine backup with either the latest or any of the older snapshots Time Machine made. It's just not bootable, but to make the SuperDuper bootable with the "convenience" sales pitch, you need to use the right form-factor drive and the skills to swap it out. Otherwise you still have to boot SuperDuper as a USB/FW drive and then copy the contents over to the main HDD, which is no gain.
You can always pay someone like me to do tech stuff for you.
Anyone tried the Air as a music server?
