Clearaudio tone arms
0 Members and 1 Guest are viewing this topic. Read 2430 times.
bogiedr
« on: 27 Nov 2010, 03:09 am »
I just picked up a Clearaudio Verify carbon fiber tonearm and a Maestro cartdrige, other than Clearaudio, what other tables can handle the combo I just picked up? Can a Lynn work with this arm?
Thanks!!
andyr
Re: Clearaudio tone arms
« Reply #1 on: 27 Nov 2010, 11:36 am »
Thanks!!
Googling it revealed it seems to be quite a light arm?  Hence it should have absolutely no problems on a Linn LP12.
Andy
orthobiz
« Reply #2 on: 27 Nov 2010, 05:26 pm »
Pivot to spindle distance on the Satisfy is 222 mm so it should fit into a Rega geometry.
Linn is 211 mm so you may have to redrill a new board if your Linn came with a Linn arm originally.
Paul
andyr
« Reply #3 on: 27 Nov 2010, 08:27 pm »
Paul
But the OP has a "Verify".
Andy
orthobiz
« Reply #4 on: 27 Nov 2010, 10:12 pm »
Verify, Satisfy, Unify, oh well, for a minute or two I thought I was a genius. I'll bet it is a 222 mm arm, though.
Paul
andyr
« Reply #5 on: 27 Nov 2010, 10:25 pm »
Paul
I agree, Paul - highly likely.   :D  I just thought I'd get my daily dose of pedantry out of the way early, this Sunday morning.  :)
Andy
