MWF-15 driver projects?
0 Members and 1 Guest are viewing this topic. Read 1944 times.
Big Stogie
« on: 26 Nov 2010, 08:54 pm »
Now that we have these drivers what kind of boxes are you putting them in. According to Bill Fitzmaurice they will work in the THT. I a going to build at least one of those, what other projects are in the works?
Mike
« Last Edit: 11 Dec 2010, 01:48 pm by Big Stogie »
django11
  • Canuckistani
Re: MWF-15 driver projects?
« Reply #1 on: 26 Nov 2010, 09:42 pm »
HTH?
I am going to try it open baffle (very soon, like tonite or tomorrow) and the probably make a sealed sandbox with the sa1 amp...
sandbagger
« Reply #2 on: 28 Nov 2010, 05:07 pm »
Mike
I am working with Mark Seaton to come up with a DIY kit, will probably use multiples of drivers in a sealed configuration, should be fun.  I dont want to say a lot till I have everything worked out and tested though.
Kevin
jwalker
« Reply #3 on: 29 Nov 2010, 11:33 pm »
I have a pair of these drivers that were pulled from MFW-15 subs with dead amplifiers.  I am looking at doing a isobaric configured sealed sub.  A 3 cf enclosure looks decent for one driver. An isobaric loaded pair should let me shrink that volume by a half and get the same performance.
I like the idea of a smaller sub for aesthetic reasons. And for DIY where a smaller enclosure is easier to build, stiffen, etc...
Rightbrained
« Reply #4 on: 30 Nov 2010, 12:07 am »
I am doing a dual opposed sealed build with my pair in a 24" cube. The enclosure will be 1.5" thick mdf all the way around.
opnly bafld
« Reply #5 on: 30 Nov 2010, 01:41 am »
Except mms is doubled, alright for ht maybe, not so much for music.  :dunno:
Lin
jwalker
« Reply #6 on: 30 Nov 2010, 04:11 pm »
Lin
I don't understand what you're implying. The whole purpose of an isobaric configuration is to reduce the Vas and enclosure size by half over a single driver which is effectively the same as doubling the moving mass.   Of course the efficiency will drop, but that's not an issue for me personally.
And its effect on the suitability for certain kinds of audio reproduction is debatable.
DFaulds
« Reply #7 on: 30 Nov 2010, 04:20 pm »
Many years ago I built a pair of isobaric subs and found them to be quite good in an all music system.  I think it all depends on the implementation.
