0 Members and 1 Guest are viewing this topic. Read 12698 times.
It is. And Oppo support is fabulous, in the off chance you were to run into any issues.
The 93 has volume control via the remote.
i don't think they have before, but can this be used as a standalone DAC?
Nope, no digital inputs of any kind
My question is around bypassing the volume control downstream, that is, of a muti-pre or avr. It would be sweet if I could go direct to a multi-amp.
The volume control is digital (affects the analog outs only, but operates in the digital domain, meaning it will eventually lop off bits), not something I'd use in a direct-to-amp setup unless your attenuation was slight, so as not to drop bits (resolution). It's really intended to slightly adjust gain of the unit so it matches your other sources. Personally, i wouldn't touch it. Why spend $1k on a player and then screw with the resolution.
Yes, but the DAC itself is 32 bit. This means you have 96dB of fully digital volume adjustment for Redbook audio without lopping off bits. There is essentially no downside to using the digital volume control with Redbook audio. It's actually a better solution for preserving the original signal than most analog solutions.
Mike,Thanks. Does it control both the digital out and analog out? Also, any experience using it direct into a multi amp? That is, level of gain?- David.
David,As the control lives on the remote, it controls _all_ audio output. I've messed with it only as a curio. In the little bit (sorry) I messed with the Oppo volume control, I wasn't noticing any loss of detail w/ volume adjustments. I guess I'll mess around with it a little more, and report back.Mike
Can any of you guys speak to the reliability of Oppo players?
I've had the BDP83SE since early Dec '09. I've had zero problems with the hardware. The firmware is something else. I've had no problems playing Blu-Ray or DVD discs, but there are a couple of bugs with SACDs: (1) the changeover of the display from one track to the next (track number and timing) falls behind the actual track, and the delay seems to get worse as more tracks go by; (2) if there are too many tracks (and I don't know the limit), then the player may, at random, suddenly stop in the middle of a track, and there is no cure but to shut off the player with the panel button. There is a beta update of the firmware that is alleged to cure the problems I've encountered, but Oppo has told me that they don't consider the beta release to be stable. When will a new firmware release be available? Last fall, they told me Dec '10, but I'm still waiting. My old Sony SACD player had no problem with any SACDs.Thanks, man
If that's what you want, get an Oppo BDP-83SE and have Modwright (Dan) mod it for both the analog section and put his very low jitter digital input board in. Now you have a nice tubed DAC and a great universal player.
It would be great if you could simply add an e-sata drive and use the 93 as a standalone DAC for 24/192 (Sabre32 chip's high end)....
