How to take out Nuforce icon board?
0 Members and 1 Guest are viewing this topic. Read 1509 times.
anzo
« on: 25 Nov 2010, 01:00 am »
Has any one experienced in opening the front/back panel of Icon?
i got the screws out, but just couldn't figure out the next step
juno
Re: How to take out Nuforce icon board?
« Reply #1 on: 25 Nov 2010, 02:36 pm »
Just pull out the knobs from theis axes, and you'll be able to get the card slip out freely.
j
nuforce-casey
« Reply #2 on: 25 Nov 2010, 06:30 pm »
Remove the front 4 screws, and remove just the Volume Knob and the nut/washer.  The front panel will come out with the selector knob still attached with a cable connected to the main board, you may carefully yank the cable connector out, or just slide the front panel with the circuit board from the rear.
