music from Mac to PC?
0 Members and 1 Guest are viewing this topic. Read 1693 times.
jtwrace
    • TIPP YouTube Channel
« on: 24 Nov 2010, 02:14 am »
Can I take HD's with my music that been uploaded using itunes on a Mac and plug the HD's into a PC with itunes and it work?
Of course the directory would need to be the same but will it work?
I upload in the AIFF Encoder format.
timind
  • permanent vacation
Re: music from Mac to PC?
« Reply #1 on: 24 Nov 2010, 02:20 am »
The HD will need to be reformatted for windows. If one of the format options lets you keep all of the files it might work.
Can't believe I'm answering this as I am fairly computer illiterate.
jtwrace
« Reply #2 on: 24 Nov 2010, 02:25 am »
Darn it!  I forgot about that.   :oops:  Yes, it's used Mac Journaled with GUID.
Can I copy from my Mac drive to another drive that is formatted differently then?
timind
« Reply #3 on: 24 Nov 2010, 02:34 am »
I think you can copy the files to something like a memory stick or flash card and then move them to the pc. The problem with that would be the limited size of the card.
If you want to go to another HD you would still need to have proper format.
I really gotta learn more about this stuff.
jtwrace
« Reply #4 on: 24 Nov 2010, 02:42 am »
Hopefully someone that really knows will chime in for both of us.   :)
I want to take my HD to work so I can listen to my music but we ONLY use PC's...
kip_
« Reply #5 on: 24 Nov 2010, 03:05 am »
Format the drive as FAT32 and you should be fine:
http://www.myfirstmac.com/index.php/mac/articles/1-external-hard-drive-for-your-mac-and-pc
srb
« Reply #6 on: 24 Nov 2010, 03:11 am »
If your Mac drive is formatted as HFS or HFS+ (likely), you can read it on a Windows PC with MacDisk.
http://www.macdisk.com/mden.php3
jtwrace
« Reply #7 on: 24 Nov 2010, 03:11 am »
I will be able to format on the Mac to FAT32?  Or do I need to do that on a PC and then plug it into the Mac and transer files?
jtwrace
« Reply #8 on: 24 Nov 2010, 03:12 am »
Thanks but I'm willing to do a dedicated drive for PC.
skunark
« Reply #9 on: 24 Nov 2010, 03:13 am »
All you would need to do is have Mac OSX format a "new" external drive as FAT32 (MS-DOS(FAT)) using the disk utility.  Once formatted, you will see the disk on the desktop/finder and all you need to do is copy the files over.
If you don't have a spare drive but do have a good backup and you have room on your HFS formatted external drive, then you could resize your HFS partition and add a FAT32 partition to start the copy over.
My advice though for work, get a second USB drive, that way you won't have to worry about theft and you can consider it an "offsite" storage.
jtwrace
« Reply #10 on: 24 Nov 2010, 03:16 am »
Yes, I will buy another drive.  No problem there.  This will be a work ONLY drive for my PC.   :thumb:
jtwrace
« Reply #11 on: 24 Nov 2010, 12:59 pm »
Next problem.
SuperDuper! can't copy to or from Windows volumes.  How do I do the transfer?
skunark
« Reply #12 on: 24 Nov 2010, 08:29 pm »
Use the finder to copy :).   If you aren't afraid of the command line you can use rsync.  I'm sure there is a GUI to synchronize directories but my command line journal is strong. :).
