Double Die Outputs?
0 Members and 1 Guest are viewing this topic. Read 995 times.
Mass. Wine Guy
Double Die Outputs?
« on: 21 Nov 2010, 03:14 am »
I'm set on buying a power amp from Frank Van Alstine but have a question. He offers what's called a double die output upgrade. My currrent speakers are pretty efficient, but this may not always be the case. Is it advantageous to have such an upgrade?
Thank you.
2gumby2
Re: Double Die Outputs?
« Reply #1 on: 21 Nov 2010, 11:54 am »
Good choice on getting an amp from Van Alstine. I own two of his Ultra amps and really like them a lot. I'm planning to get the double die upgrade in the near future because I want to buy some Magnepans and they have a reputation of being power hungry. So, yes, I'd recommend the upgrade so you'll have plenty of power for what the future might bring.
Mass. Wine Guy
« Reply #2 on: 21 Nov 2010, 10:27 pm »
That sounds like a wise ting to do then. Thank you. Do I need to upgrade all four of the outputs on the amp I'm getting, or are two (for speakers) enough?
srb
« Reply #3 on: 21 Nov 2010, 10:43 pm »
The double die upgrade replaces all of the MOS-FET power output devices in the amplifier (4, 8 or 12 devices, depending on the model).
