Audio Nirvana
0 Members and 1 Guest are viewing this topic. Read 6486 times.
luckylou
Audio Nirvana
« on: 21 Nov 2010, 02:11 am »
Hey all I just finish my open baffle speakers .. let me say these were a pair that I own and love them but I felt that the speakers were to big so I had to cut them down a bit and dress them up ..
These are the audio nirvana super 12inches cast frames ..
I have added brass binding post to them I use sliver wire to connect them to the speakers as you can see . I also use the same wire to connect them to the binding post ..
Mind you these were pretty big at the start when i first made them but I just couldn't see them that big in my room ...
I added a touch of my own to them so here goes ..
luckylou
Re: Audio Nirvana
« Reply #1 on: 21 Nov 2010, 02:17 am »
here is what they look like before the make over by the way there in my gallery . so you can see the before and after work ..
Saurav
Re: Audio Nirvana
« Reply #2 on: 21 Nov 2010, 03:05 am »
Can you post a close-up of that embossed logo / graphic? How did you do that?
luckylou
Re: Audio Nirvana
« Reply #3 on: 21 Nov 2010, 03:38 am »
Hey I was in home depot it's a trim that is use on doors and it look nice all wood it's not that thick the cost was like 3.39 each the button on the speakers were tap with a 3/4counter sink the cost of 40 buttons at ace hardware was 5 bucks the side trim was a home depot which is also a wood trim for doors a other 10bucks so i didn't spend much just put a bit of thought and there they are will post better pictures .
Re: Audio Nirvana
« Reply #4 on: 21 Nov 2010, 03:55 am »
Very nice job luckylou enjoy   :thumb:
luckylou
Re: Audio Nirvana
« Reply #5 on: 21 Nov 2010, 04:12 am »
Thanks now waiting for my integrated amp to be deliver and I will ..
luckylou
Re: Audio Nirvana
« Reply #6 on: 8 Dec 2010, 01:19 pm »
Hey I think i finish the audio room for now till I get a other itch ,,
the speakers are the same , i just added this integrated amp Custom made S-5 electronics 8 watt/channel stereo integrated tube amplifier, using four  11MS8 tubes i added the tube dampers to it ..
10 ft pair of Straight Wire Stage speaker cables terminated on both ends with BFA bananas. interconnect are 1 meter pair of Tributaries RCA cables, marked A2 Silver,
1 meter pair of Phoenix Gold Pro Series Symmetry Cable with locking RCAs and directional arrows on the cables.
I have a tube buffer by Z-Man Audio Signal Enhancer. between that i have a Taddeo Digital Antidote,
Using a denon 3900 CD DVD player . the TT you see is not being use as I await a find on a new TT
Theta Cobalt 307 DAC  is not being use either will post it up for sale .
Trying to keep it sweet and simple and loving the sound .
