0 Members and 1 Guest are viewing this topic. Read 10090 times.
Mike, you did not say which Parasound equipment you showed your wife. If it was not the Parasound Halo line, you might check to see if that passes muster.
If you are intending to use a separate surround sound receiver or processor in conjuction with a 2 channel preamp, the Parasound Halo P7 and the just-released JC2 BP both have an HT bypass input, whereas the P3 and JC2 do not. Steve
You mentioned using the C1 controller with your amp. Was that replaced by the JC2, or something entirely different? T
Another option is a Musical Fidelity integrated:http://www.musicalfidelity.com/products/M6-Series/M6i/M6i.asp
I have been thrilled with my McIntosh MA-6500 paired with my Salk SongTowers. LOVE having tone controls again, mono switch, loudness, etc. My wife loves the way it looks and it sounds wonderful. I paid ~$2k used.Those meters are nice. I was also considering the Luxman L-505u which has similar meters. $2000 is a really good deal. I thought i remember the ma-6600 retailing for $6k.
