0 Members and 1 Guest are viewing this topic. Read 4997 times.
Arild,The wires are fine, the copper wires used are insulated with a thin layer of polyurethane or something. It won't short unless some of that has been burned or scrapped off. I have a NOH too and the thing I would recommend is check to see if there are any shorts on the L channel selector switch....but it is normal to have a "click/pop" or something when changing inputs.Tuan
