James? Cat Tolerance?
0 Members and 1 Guest are viewing this topic. Read 2699 times.
Mike-48
« on: 20 Nov 2010, 06:16 am »
James, my trusty 14B ST is still giving much pleasure. In our new house, the equipment layout has changed, and the cat has taken up residence on the amp. I suppose this blocks some of the airflow through the cabinet. Given that I don't push the amp very hard, is this likely to cause any problems with the amp?
Mike
  • The Demo is Everything!
    • http://www.bryston.com
Re: James? Cat Tolerance?
« Reply #1 on: 20 Nov 2010, 11:54 am »
Mike
Hi Mike
As long as no kitty-litter is required all is fine :D
James
1oldguy
« Reply #2 on: 20 Nov 2010, 01:15 pm »
LOl That's a new one.Ok...I'll bite.Think of it this way.If some cat hair gets into the vents as I'm sure it will.You will be smelling putty tat every where when things get hot.
You just may be the envy of the neighborhood with such a stench.Hey some live for the stuff.  :green: :thumb:
1ZIP
« Reply #3 on: 20 Nov 2010, 03:53 pm »
It would be interesting to see if the warranty covers "hair ball" damage. :)
Mike-48
« Reply #4 on: 20 Nov 2010, 06:56 pm »
Hi Mike
James
Thanks, James. The cat will be very happy. The B14 is his electric blanket.
ec
« Reply #5 on: 20 Nov 2010, 06:58 pm »
Mike,
If you ever sell your 14B - I assume you can not advertise:  "from a pet free environment" :D
rob80b
« Reply #6 on: 21 Nov 2010, 12:00 am »
Mike
Got the same problem, you can place something like a small sculpture in the center or just pick them gently up by the scruff of the neck and give them a little speech.
At least the amps are pretty indestructible unlike my headphone boxes.
Laundrew
« Reply #7 on: 21 Nov 2010, 02:56 pm »
:scratch:
Be well...
Stephen L
« Reply #8 on: 22 Nov 2010, 03:18 pm »
 Step away from the stereo
klao
« Reply #9 on: 22 Nov 2010, 04:00 pm »
This guy and his friend prefer cooler places (because of their long hair and warm weather we're in), but should I somehow try to lightly vacuum their hair that might fallen into the inside of the amps?
« Reply #10 on: 22 Nov 2010, 04:27 pm »
Sure - a vacuum will not hurt the amp.  Turn it off first of course. :D
james
ian.ameline
« Reply #11 on: 22 Nov 2010, 05:32 pm »
"You have 10 seconds to comply... 9... 8... 7"
