New Bryston SC4 speaker cables
0 Members and 1 Guest are viewing this topic. Read 32297 times.
vengky
Re: New Bryston SC4 speaker cables
« Reply #60 on: 14 Jun 2011, 10:28 am »
In general (and for ease) always go in the direction of the text printed on the cable. So:
AMPLIFIER ===> this is the text printed on the cable ===> LOUDSPEAKERS
And not:
LOUDSPEAKERS ===> this is the text printed on the cable ===> AMPLIFIER
Yes you are right but I am wondering whether I can use them in reverse cause I need to connect the 2 pair via the bananas at the amp end. I guess will have to try to see how it sounds.
VK
StigO
« Reply #61 on: 14 Jun 2011, 02:42 pm »
Would the cable sound different going:
LOUDSPEAKERS ===> this is the text printed on the cable ===> AMPLIFIER?
And not:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #62 on: 14 Jun 2011, 02:46 pm »
We have done extensive testing (even employing molecular directional signs) and so far the electrons in the Bryston speaker wire have not learned or are unwilling to learn which direction they are suppose to go in :thumb:
james
Alpha10
« Reply #63 on: 14 Jun 2011, 02:52 pm »
james
You do know someone will ask for those now as an upgrade  :duh: :duh:
Cheers
werd
« Reply #64 on: 14 Jun 2011, 03:10 pm »
Hi Dave,
The large spades we sell are heavily gold plated and snap into the bnding posts on the Bryston amps.  It provides a large non corrosive surface and a molecularly tight fit. On most speakers the binding post sometimes will not accept a spade very well so I find our 'expandable' banana works better in most cases.
james
So then the molecules are made of "pure crystal" ?  :scratch:
« Reply #65 on: 14 Jun 2011, 03:15 pm »
Preferably in a connection gold to gold molecules. :thumb:
james
vengky
« Reply #66 on: 14 Jun 2011, 03:54 pm »
james
 :lol:
werd
« Reply #67 on: 14 Jun 2011, 03:58 pm »
james
 :wink:
Alpha10
« Reply #68 on: 14 Jun 2011, 05:25 pm »
Slightly more on topic, I had hoped to get some of this cable to go with my new 4BSST2 I have on order, but unfortunately the shipping to the UK and the new costs of the connectors makes it a bit expensive.
James is there any chance of PMC stocking this, to make the price (assuming PMC don't put on a big mark-up) a bit more accessible over this side of the pond?
Cheers
« Reply #69 on: 14 Jun 2011, 05:37 pm »
Cheers
Hi - I think our export manager discussed it with PMC but they did not feel it had much of a market in the UK.
james
Alpha10
« Reply #70 on: 14 Jun 2011, 05:48 pm »
james
That is a shame, thank you for letting me know.
I might just send them an email, in case they have second thoughts..
Cheers
vegasdave
« Reply #71 on: 15 Jun 2011, 04:35 am »
james
 :icon_lol:
klao
« Reply #72 on: 15 Jun 2011, 03:28 pm »
Hi James.
Wonder if you and the team used Bryston cables (IC, speakers, digital, & AC) exclusively in all listening tests for your product development, whether in Bryston's facilities and in your many rooms and setups at home?
Thanks.
vegasdave
« Reply #73 on: 15 Jun 2011, 08:12 pm »
Good question! I would like to know this as well...
« Reply #74 on: 15 Jun 2011, 09:31 pm »
Hi James.
Thanks.
Usually at home for the listening tests because I can do a double blind test.
James
vegasdave
« Reply #75 on: 17 Jun 2011, 11:42 am »
James, do you find that the system sounds better with all Bryston cables?
« Reply #76 on: 17 Jun 2011, 11:57 am »
Better is a tough one as I find one persons better is sometimes another persons worst.  What we try to do with our Bryston cables is reduce the cables affect on the electrical signal as much as possible - recognizing that the best cable is no cable at all.
james
vegasdave
« Reply #77 on: 17 Jun 2011, 12:29 pm »
Yeah, that's true. And I agree. I will be ordering some speaker cable in the future.
frankg
« Reply #78 on: 30 Jun 2011, 03:14 pm »
Do the small spades fit on the cables in a standard L/R wiring? The web site says 10 gauge is the largest, however I see a few pictures that seem to show the small spades being used.
« Reply #79 on: 30 Jun 2011, 03:56 pm »
Hi Frank - I would not recommend the small spades with our cables.
james
