0 Members and 1 Guest are viewing this topic. Read 32292 times.
Hey James, what's the minimum length I would need for the 4BSST to each speaker? 4 or 5 ft? The amp is directly between the speakers on a Target base.
The speaker cable has to be long enough to reach from the amp to the speaker james
Haha, I know that. But how far apart should I have my speakers. Well, anyway, I suppose 4 ft. will be enough...
Dave,Depending on the dispersion characteristics of your speakers try to separate the speakers the same distance you are away from them. So if you're 8 feet away separate them by 8 feet or slightly less. You do not want a hole in the middle of the sound stage but you also want as wide a soundstage as possible.james
Hi James,which termination would you recommend for these speakercables to connect the 28b's to Quad ESl63's? And how would I have to preceed in ordering them? They would have to be about two feet long.Grtz,Marius
Hi Marius I would recommend the large spades on the amp end and the bananas on the speaker end. Just email Melissa at Bryston if you want a set - [email protected]James
Why not bananas at the amp end, James?
Some amps do not take bananas.
Hi Dave,The large spades we sell are heavily gold plated and snap into the bnding posts on the Bryston amps. It provides a large non corrosive surface and a molecularly tight fit. On most speakers the binding post sometimes will not accept a spade very well so I find our 'expandable' banana works better in most cases.james
Hi James,I was thinking about getting some of your new speaker cable to go with my new 4BSST2, but from the UK do I need to go through PMC or can I buy directly from you guys, or would the postage be prohibitive?Cheers
Direct - PMC does not carry the cable. Contact Melissa at Bryston and she will give you a cost. [email protected]james
Hi James,I ordered with [email protected] as you hinted, but never got an answer. Mmyles@bryston should do the trick? Marius
So my question is are the signal flow of the speaker cables engineered for 1 direction only.
