0 Members and 1 Guest are viewing this topic. Read 3969 times.
What are the rest of you guys using, particularly the ones with Geddes or similar concept mains?
The latest research has shown that in addition to your mains, controlled directivity is also recommended for the surrounds (Toole, Geddes, etc...). Josh if you could swing the bucks you will also consider Geddes' Harpers which is what I'll be using in my system (4 of them actually). If you want to control dispersion down to a low enough frequency that is audible, you need larger waveguides. Tiny waveguides, that are a bit bigger than a 1 inch tweeter, imho, are just a marketing tool. Good luck! You might want to also look at Hsu's HB-1 MkII. It's small and cheap. When your venue and budget gets bigger, spring for the Harpers.Anand.
I second the Hsu idea, it will sound better than most of the pro speakers as the pro speakers require a fair bit of EQ to get them flattish.
Abbey clone!Time for you to have another Rave!
