0 Members and 1 Guest are viewing this topic. Read 5466 times.
You could also try a D-Lite High Power screen; it would be near that price. How is your projector mounted? On the ceiling or floor or wall?
The only problem with the projector central calculator is that you can't tell how it was determined. It probably uses the highest bulb setting with a new bulb.
It's going in a dark basement for heaven's sake. And 1600 lumens is not dim. We all forget - the brightest CRT projectors were 400 lumens!!!If it were going in the living room where there were windows (and no shades), then I might suggest a high gain screen, after evaluating the room. Actually I'd probably recommend a direct view display in that case...
....the last decision point I have is on the BLue ray player...is there a BLue ray DVD player that upscales regular def. DVD's, streams netflix and works over a wireless N router?... Springs home theatre recommends a panasonic wired Blue ray player but I would like to go wireless if I can egt the same or better quality as wired...
p.s. Don't forget to post pictures of your room in the sticky thread.It's been a bit sparse lately.
