SAD Therapy Lamp Recommendation Needed
0 Members and 1 Guest are viewing this topic. Read 3848 times.
bpape
    • Sensible Sound Solutions
« on: 18 Nov 2010, 04:55 pm »
I need to invest in a good light therapy lamp for my wife.  There is a lot of conflicting information out there with regard to the spectrum needed, how much brightness, wild variances in pricing for things that look similar,etc.  Any recommendations/personal experiences would be greatly appreciated.  Would prefer something that can be used full time while working at a PC rather than something that one needs to just sit in front of specifically and not doing other things (very Type A personality...)
Thanks in advance.
Bryan
mikef
Re: SAD Therapy Lamp Recommendation Needed
« Reply #1 on: 18 Nov 2010, 05:24 pm »
I am using a lamp called "Daylight" from Uplift Technologies that I bought from e-bay for around $100. It's 10,000 Lux, comes with a floor/table stand, 2 levels of brightness, and is small enough to place on my desk. 20 minutes in the morning while I checked my e-mail made a positive impact in my mood last winter.
Another thing to check out is Vitamin D supplementation, which I find helps SAD as well (for me).
Mike Fox
bpape
« Reply #2 on: 18 Nov 2010, 07:21 pm »
Thanks.  I'll check that one out.
Bryan
Mike B.
« Reply #3 on: 18 Nov 2010, 07:59 pm »
I have a Sun Touch Plus on my home office desk. I turn it on in the morning when I am doing my morning e-mail and surfing. It has a built in timer and air purifier.
« Reply #4 on: 18 Nov 2010, 08:00 pm »
Also, 5000 iu of Vitamin D3 per day will have a very positive effect on SAD.
rpf
« Reply #5 on: 18 Nov 2010, 08:47 pm »
Mike Fox
Second both recommendations.
bpape
« Reply #6 on: 18 Nov 2010, 08:49 pm »
Thanks for the recommendations.  The Daylight (uplift) looks like a winner.  Will try the Vitamin D also.
Need to check out the negative Ion thing a little more.
Bryan
django11
  • Canuckistani
« Reply #7 on: 18 Nov 2010, 08:57 pm »
I use the Saddelite which delivers 10,000 lux.  It is more expensive but could probably withstand a nuclear blast and uses two tubes instead of three.  Tubes are fairly pricey.
bpape
« Reply #8 on: 19 Nov 2010, 12:24 pm »
Will check that one out too.  Thanks
Bryan
django11
  • Canuckistani
« Reply #9 on: 21 Nov 2010, 01:20 pm »
I also have a "sunrise simulator".  Basically an alarm clock that gradually lights up in the morning, simulating sunrise.  Looks dumb, sounds dumb but I really like it and find it helps a lot getting up at 6 am in the winter.  My wife really dislikes it though  so I haven't power it up yet.  I will soon though...  I have this one
Mike B.
« Reply #10 on: 21 Nov 2010, 04:57 pm »
This is what my primary care doctor uses. If I was still working and getting up early I would have tried it. :D
audioengr
« Reply #11 on: 21 Nov 2010, 06:02 pm »
Just take 1000IU of good vitamin D (such as cod liver oil pill) every morning and you will not get SAD.
I have lived in Oregon and Portland for 25 years, so I know gray skies.
Steve N.
Empirical Audio
