0 Members and 1 Guest are viewing this topic. Read 2376 times.
Does anyone use copper tape as shielding material? My only other option is to line the box with copper sheets. Tape just seems so much easier.
The copper foil that 3M sells works..........I've used it in guitar bodies to shield pick ups from radio frequencies. The underside of my turntable top plate is covered with it.......it stops RFI, but has zero effect on EMI.
