What small slow blo fuse amperage ranges can be used with the bugle pro
0 Members and 1 Guest are viewing this topic. Read 1328 times.
xtreme4099
Thinking of trying some aftermarket fuse and they're only available in certain amperages
Sergio
Bugle Pro with LME49990 opamps and Vishay Z-foil tx2575s resistors.
hagtech
    • http://www.hagtech.com
All you need is something in the 1/8th amp to 1 amp range.
jh
xtreme4099
Thanks much, ill chime in here and give my opinion on the fuse thingy, see what changes vs the regular run of the mill fuse, ive done this before with a headphone amps powersupply with good results, swapped out for a furutech fuse swapped them back and forth with several people in attendance and everyone definitely noticed a difference, silky smooth a more natural decay to notes, so we'll see what it does to the preamp.
