C203, 206 voltages and C200, 206 options.
0 Members and 1 Guest are viewing this topic. Read 1816 times.
tubesorbust
« on: 15 Nov 2010, 08:56 pm »
I'm inquiring about the voltages on the capacitors, and I've read several posts on the subject but no clear reason on why it shouldn't be done other than, just build it with the specs given.  When I read the schematics C203, 208 have voltages of 150V and 155V respectively.  I'm thinking about getting the following for the capacitors:
Sonicap Gen1 C208 1uF/200V
Sonicap Gen2 C203 .1uF/200V
According to Sonicraft they are tested at twice the voltage (mil-spec) and even with surge it still won't hit the 200V on the line.  So would this be a viable solution?
Also I spoke to someone who suggested using a .033uF 400V platinum cap in C200, 206 as the bypass cap.  It seems as if that is a far cry from the 1uF required.  I'm wondering if someone out there could explain why or why not be a viable option for educational purposes.
tubesorbust
Re: C203, 206 voltages and C200, 206 options.
« Reply #1 on: 15 Nov 2010, 11:19 pm »
Oh, and I forgot to mention it's for the Cornet 2.   :duh:
poty
« Reply #2 on: 16 Nov 2010, 06:17 am »
In DIY field you are expected to hit if not one, then another part's cost. The Cornet 2 has only basic means of protecting against possible failures. Then for:
They may have as much as full B+ in case of heating voltage failure, tubes failure and many other factors.
...they are tested at twice the voltage (mil-spec) and even with surge it still won't hit the 200V on the line.  So would this be a viable solution?
IMHO, no. The testing uses new parts in controlled equipment and environment and for limited period of time. You have in the device neither of the provisions .
...someone ... suggested using a .033uF 400V platinum cap in C200, 206 as the bypass cap.  ...that is a far cry from the 1uF required.  ...why or why not be a viable option for educational purposes.
I don't think the change is suitable for the caps. The caps are used for "shorting" power supply for the signal, so they are essential and important part of the signal part. Their values have been chosen in such way that they have reasonable small impedance for the frequencies which is not covered by electrolytic caps. Lessening the values leds to changing the tone balance in the frequencies mentioned.
tubesorbust
« Reply #3 on: 18 Nov 2010, 01:17 am »
Thanks for the reply.  I decided to go with the values as specified per Jim.  I went with:
Sonicap 1uF / 600 Gen 1
Sonicap .1uF / 400 Gen 2
Let's see if I can get this baby singing!
