Squeeze Commander Changes Song Order
0 Members and 1 Guest are viewing this topic. Read 1002 times.
cloudbaseracer
« on: 15 Nov 2010, 04:14 am »
I use the Squeeze Commander program on my Driod X to control my Squeezebox Touch and I like it very much. It is a little slow at times, it hangs up occasionally and it could use a few more features.  The biggest gripe I have though is that when I add a whole album to the playlist it shuffles the order for some reason. It also, does not "add songs to end of playlist" as the command says.  It will generally put them in just after the currently playing song.
Do you guys have any explanation for this?  I have tried to find a forum for the program but have not been able to locate one or anything that covers this issue.
James
mitch stl
Re: Squeeze Commander Changes Song Order
« Reply #1 on: 16 Nov 2010, 01:06 pm »
You might check over at http://forums.slimdevices.com. The fellow who wrote Squeeze Commander (flattermann) hangs out there a bit along with a number of avid users.
