FS: Lipinski L-505 Monitors
0 Members and 1 Guest are viewing this topic. Read 5988 times.
Lynn Fuston
« on: 12 Nov 2010, 07:19 pm »
For sale is a pair of Lipinski L505 studio monitors. They are in great condition, a 9 out of 10. Featuring dual 5" woofers and a Neodymium tweeter, these work great combined with a sub (I used a 10" Velodyne). Binding posts allow for bi-amping. Foam-lined carrying cases are included.
$1850 (obo) for the pair. Shipping not included.
Contact me at 3daudio @ charter.net
Stats are:
Three-In-One [Sland alone, in wall, On-wal]
One 1" (25mm) Neodymium Ring Radiator tweeter
Two 5" (14cm) Glass Fiber Mid Woofers in MTM configuration
Frequency response: 71Hz-20kHz ±1dB (46Hz-40kHz ±3dB)
Speaker-to-speaker consistency: ±l/4dB.
SPL: 90.5 dB lW/lm
Impedance: 4 Ohms
Dimensions: 20"H x 8"W x 5.5"D (50cm x 20cm x 14cm)
Weight: 20.9 lbs (9,4 kg)
Source: http://lipinskisound.com/products/l-505a-monitor/
From the MIX magazine review:
The L-505s (and the larger L-707s) are a passive design in sealed enclosures. Lipinski states that the presence of an internal amplifier creates unacceptable results — up to 15-percent second-harmonic distortion — on its speaker's response curve. Furthermore, a few feet of good heavy-gauge wire won't diminish performance, rendering any “self-powered” issues moot. The beefy connectors certainly won't impair signal flow either.
The heart of the magnetically shielded L-505 speaker point-source design is the 1-inch neodymium ring-radiator tweeter and its placement. Time alignment is accomplished acoustically with depth positioning instead of electronic or crossover-induced delay. The crossover is built with premium-quality parts: foil inductors and oxygen-free copper wiring throughout. The tweeter is center-positioned between the two 5-inch (top and bottom) glass-fiber mid woofers. Specially designed textured Belgian foam eliminates side reflections, resonances and other anomalies — all designed for the best imaging and flattest frequency response possible. It is suggested that the tweeters should be at head level for the best imaging and the speakers should be placed on a solid, stable surface. Sand or lead shot-filled, heavily anchored supports are recommended, or use Lipinski's L-36 36-inch stands.
On the rear, two 1-inch gold-plated brass connectors per post give plenty of surface contact area for spade lugs, 2AGW wire or banana plugs. Although rated to run efficiently on as little as 75 watts RMS, the L-505s are stated to accept much more power than that.
Lipinski recommends using a subwoofer with these speakers and makes its own supplementary subs: models L-150 and L-150G. The smooth 70Hz roll-off matches my own sub perfectly; the hand-off is smooth and coherent. Even with the sub switched off for testing, the L-505s delivered a smooth, solid sound all the way down to 40 Hz. Mid bass didn't get muddy or sloppy; everything stayed tight down to the subwoofer crossover point.
[SIZE="1"]Source: http://mixonline.com/mag/audio_lipinski_passive_monitors/[/SIZE]
Wayner
Re: FS: Lipinski L-505 Monitors
« Reply #1 on: 12 Nov 2010, 10:16 pm »
Nice that your first post is selling something. BTW, you sound like a dealer (from your email address) and you are in the wrong circle for selling this stuff (see the rules of the market place).
w
Rocket_Ronny
    • ScriptureSongs.com
« Reply #2 on: 12 Nov 2010, 10:38 pm »
Hi Wayner:
Lynn is a recording engineer. Very well known and a nice guy. I bought his mic and pre amp comparison cds and found them very helpful. He is also a serious Christian which I can get into. I doubt very much this is any dealer type sale, but I could be wrong. If so I am sure he will repost.
Rocket_Innertube Mag Mic into Neve Portico 5012 into Metric Halo_Ronny
Wayner
« Reply #3 on: 12 Nov 2010, 10:48 pm »
Not that I really care, but I've noticed that there are lots of johnny come latelys to the AC that only post things for sale and not contribute one thing to the circles. Perhaps none of the "masters" care, but I think the free adds are being taken advantage of a bit.
I'm sure he's a good guy, but his email address is 3daudio @ charter.net and it sounds like a business to me and the rules say that he should be in the "industry adds", not in this circle.
Wayner
Rocket_Ronny
« Reply #4 on: 12 Nov 2010, 11:37 pm »
I hear you. He most likely is just advertising like you say.
He has his own recording circle so I don't know how much he would visit here. But if he did then we would all benefit. So would he actually. A lot of knowledge here.
Rocket_OktavaMod 319 into ULN2_Ronny
