Cornet 2 replacements for 2SC3942
0 Members and 1 Guest are viewing this topic. Read 2168 times.
Lengy
« on: 11 Nov 2010, 08:08 pm »
I've read through the forum and think I've found the correct replacements for the 2SC3942 transistors, the ones I've bought are the 2SC3503FSTU-ND TRANSISTOR from Digikey.  Are these correct and which way round do they go as I can't find any anywhere in the instructions that tells me which how to fit them?
hagtech
Re: Cornet 2 replacements for 2SC3942
« Reply #1 on: 14 Nov 2010, 04:50 am »
TIP50.
jh
Lengy
« Reply #2 on: 14 Nov 2010, 09:51 am »
Thanks for getting back to me, I've ordered those, is the orientation obvious?
hagtech
« Reply #3 on: 20 Nov 2010, 05:52 am »
Yes, metal tab mounts to heat sink.
jh
