8" midbass driver any suggestions
0 Members and 1 Guest are viewing this topic. Read 2470 times.
versus rider
« on: 9 Nov 2010, 08:48 pm »
Hi all, you'll be pleased to know that even though I am now running compression driven horns for mid and hf I still run open baffle bass. What I need though is something to run between my Eminence alpha's cut off at 200 - 250Hz and my mid horn at 800 - 1000Hz, it needs to be an 8" to replace my wideband driver 70Hz - 18KHz. I am at last approaching what I have been working towards for some two years, hopefully then I will be able to sit back, relax and enjoy the music..........yeah right!
scorpion
Re: 8" midbass driver any suggestions
« Reply #1 on: 16 Nov 2010, 08:42 pm »
A very good unit will be 18 Sounds 6ND430, no doubt !
/Erling
mcgsxr
« Reply #2 on: 16 Nov 2010, 09:46 pm »
How efficient does it need to be?
JohnR
« Reply #3 on: 16 Nov 2010, 11:08 pm »
What driver do you have now?
versus rider
« Reply #4 on: 17 Nov 2010, 07:13 pm »
as efficient as possible, mid horn is 118db and hf horn 113db. I do have some ability to attenuate them through the Behringer. The 8" driver I have is a bit of an unknown but I believe its 95db, 10w and looks very much like a driver available from Altronics, Australia
