0 Members and 1 Guest are viewing this topic. Read 12556 times.
HI All,I have my music archived in Apple lossless but would like to now have it archived in lossless uncompressed format (like aiff). If I convert the Apple Lossless to aiff will I have the same file (data) as if I were to rip the CDs directly into aiff? If so, it woudlsave me a lot of time.Any help would be appreciated.Cheers,Rafal
Sorry to tell you this but I believe all you did was use up more memory. You CANNOT go from a lower format to a higher format. It would be the same as trying to convert a mp3 file to an aiff file.
You can do this and the files will be bit-perfect, but it's unnecessary, like storing a gallon of gas in a two-gallon jug...
Apple Lossless or FLAC files are not a "lower" format. They contain all of the bits that an uncompressed AIFF or WAV file does. It is not the same as converting a compressed MP3 file to an AIFF file.If the file conversion software is working correctly, the files will be bit-perfect. Steve
