Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
Lightspeed attenuator with a Clarinet?
0 Members and 1 Guest are viewing this topic. Read 7663 times.
schubert
I'm the one on the right
Re: Lightspeed attenuator with a Clarinet?
Reply #20 on:
25 Nov 2010, 03:02 am »
I won't tap the board at all - I'll do the same thing I did for the remote control board in the last unit I built - put in a second transformer, and add a rectifier/regulator.
audioray
Reply #21 on:
26 Nov 2010, 03:50 pm »
could you do a small sketch [pictorial] and a parts list
thank you
schubert
Reply #22 on:
26 Nov 2010, 05:19 pm »
I'll use the regulator circuit descrbed on Uriah's website (bottom right corner of pic below)
I've decided to try a 9V battery as the source first, and if that doesn't work I'll try this
Do you want parts for the PSU only or the whole unit?
Good luck
Other Stuff
Hagerman Technology
hagtech
