0 Members and 1 Guest are viewing this topic. Read 7501 times.
oh and i should add the HT2's sounded pretty damn good in a real small hotel room at rmaf.
If the HT2-TLs are in your budget, get them. Do not compromise your speaker purchase because of your temporary situation, you will only regret it later. Your temporary room certainly won't be ideal, but I can't imagine why you wouldn't be able to get absolutely great sound with a little setup effort and some acoustic room treatments.
Hi Piffle, If you could put the system on the diagonal in that corner I think it might work out better sonically. Just a thought, Tish
You guys are awesome. Thanks for the replies so far.So the opinions seem divided between going ahead with the HT2-TLs and getting something like the SongSurround. My question to you guys that recommended monitors is, do you think the monitors will actually sound BETTER in this space or did you make that recommendation because you think they will sound the SAME for a lot less money? I am resigned to doing at least some acoustic treatments, if that matters.
I think the surrounds will sound best with the least monkeying around with a small room. If you go surround sound later then you are on your way if you buy Song Surrounds and a Songsub now. Then a bigger room later is perfect to expand by moving the surrounds to the back and getting larger mains.
