Power amp clip
0 Members and 1 Guest are viewing this topic. Read 1454 times.
Janedoe
Power amp clip
« on: 5 Nov 2010, 07:00 am »
I have a bryston power amp. I experimented with putting a tube pre amp to the bryston. After powering up the pre amp, I powered up the power amp and there was a very loud pop sound from the speakers. The LED light for the left channel was red during the pop sound and then changed to green. I would like to ask:
1) what could be the reason for the sudden explosively loud pop sound? DC voltage?
2) could this have somehow damage the power amp/ speakers? I later used another preamp and they seem to be working. Not sure if there might be some residue damage? Any need to take them for a check?
Thanks for your feedback and advice
Stephen L
Re: Power amp clip
« Reply #1 on: 6 Nov 2010, 01:39 pm »
Did you have the volume turned up too high?
