0 Members and 1 Guest are viewing this topic. Read 2648 times.
Thankssorry i did not take any photos. You could barely see the break right at the solder terminal.Any I rewired the mids yesterday and the first layer of NF 30 is curing for 24 hrs then a second coat goes on and let it cure for a few days before I listen.I will post after it is back up
Any way I will be doing the other side as well along with two other panels I purchased for experimenting with (mainly or have spare ribbons handy).Its tedious but I am using DAP to secure the the starting point. Then apply a bit of DAP at the other end and on the loop, let it set then stretch and apply, then back down to the bottom, apply a bit of DAP to mylar and the wire, let it set then stretch and apply, then back up and repeat. Once all the runs are in place(two separate loops for the IIIa's) I paint a small are of NF30 in the middle of the run and make sure the wires are centered in the area between the magnets. You have time to move the wires a bit as the NF30 sets up. Once that sets then I can apply a coat for the whole length. Let that set for 24 hours the a second coat. I thinks this is a pretty good method, but the proof will be in the playing, which will be this coming week end. I just did not like the way the 3M super 77 set up and it look like to me that there was just too much mass. Looking closely at the original (factory) It just looked like to me that they just used NF30. I think Maggy's directions in the rebuild kits to use 3M Supper 77 is to make it go faster because it setup so quickly. I maybe wrong but I will find out.
